98+ Exhaust on a 96 maro issue - FirebirdV6.com/CamaroV6.com Message Board
  • 98+ Exhaust on a 96 maro issue
    There are differences with how the muffler inlets/outlets are, the 98+ muffler must sit a little further back than the pre97 exhaust.
    My best option that I can think of at this point would be to flip the muffler the upside down, cut off the drivers tail-pipe (which is attached to muffler, pass. is bolted on) and have it welded back on the correct direction, however, doing this will mean the tail-pipes will be roughly 6" short of the rear...
    This is what I am going to have to do, however, I thought I would just see if anyone else had some suggestions or ideas of how I can get this to work without cutting the system apart (it's stainless steel, my dad said he cannot weld that metal, so I would have to take it to a shop)
    1999 Camaro Z/28
    1973 Firebird Formula
    Re: 98+ Exhaust on a 96 maro issue
    so are you trying to figure out how this will mount up under your car?? I dont really understand what your asking here, cause i dont know if you mean you have this setup now or what, but my guess would be to just weld on new exhaust hangers and problem solved. The pipes from the 98 and up should fit with minor adjustment.
    2000 v6 a4 Camaro
      It should fit, except that you will need the 98+ hangers which are very different from the 93-97 hangers.
      Raven
        the hangars seem to be the same on the drivers side, the pass side is different
        However, the inlet tube sets the muffler further back. I'm going out now to mess around with it
        1999 Camaro Z/28
          What I-pipe are you using? You need to have a Borla, not a stock pipe.
          Raven
            it's the borla cat-back, so yep the borla i pipe
            I'll go give it another try, maybe I was messing something up yesterday
            but it seemed as both I-pipes went to the same location, which means the muffler locations were different, but I was tired so I prob. was missing something
            1999 Camaro Z/28
