Headers - FirebirdV6.com/CamaroV6.com Message Board
Headers
  • Headers
    Quick question before i buy my headers...they come with detailed instructions of how to install them correct? Cuz i dont have much of an idea at all, but im getting some friends to help out that do but im hoping they come with some decent instructions
    Re: Headers
    it's pretty straight forward..jack the car up, take the manifolds off and put the headers on. make sure you've got some new gaskets and you should be set. What brand did you get?
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      Re: Headers
      There's also a tut on here in the How-To section.
      ~97 3.8L V6 Camaro~
      A few things
      Only Member of Team Hooker?!?
        Re: Headers
        If you're new to car modding i'd have a shop it for you.
          Re: Headers
          its really not that bad, just time consuming.
          remove dipstick tube
          remove heatsheilds
          remove manifolds
          put on the headers
          id get better gaskets, and try to leave a stud in on each side to help put the headers back on. depending on your car, you might want to replace your spark plugs as they're a breeze to do once you get the headers on.
            Re: Headers
            I got pacesetter ceramic coated, i talked to some of my buddies so hopefully we can figure it out, you dont have to pull the motor do you?
              Re: Headers
              I didnt see anything about headers in the how to section
                Re: Headers
                you don't have to drop the motor. You just remove the manifolds from underneath the car, then isntall the headers, again from underneath, so a lift is very helpful.
                Here's the link for the Tutorial
                ~97 3.8L V6 Camaro~
                A few things
