if you ever blow out your mass air flow screen - FirebirdV6.com/CamaroV6.com Message Board
  • if you ever blow out your mass air flow screen
    if you ever blow out your mass air flow screen, make sure to take off your upper intake to make sure that nothing is in there. this happened to me after 2 nitrous back fires in the begain of march, and i just found out when i pulled apart my engine yesterday
    http://forum.camarov6.com/showthread...874#post726874
    WAWA-A-HOLIC
    Re: if you ever blow out your mass air flow screen
    Good tip. You always have to check everything when there are mishaps! Must've sounded a little weird..
    2004 CE Corvette 10.86@132mph
    2011 Cadillac CTS-V
    2006 Mitsubishi Eclipse GS
      :omg: good thing it got stuck in the intake and not any farther.
      -Y87
      Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
        it did go further, got down to one spark plug and with it getting beaten by the piston it killed the spark plug
        WAWA-A-HOLIC
          wow! You got lucky you didn't ruin the piston.
          -Y87
            This is a reason I may never run nitrous on my car along with other things that can happen with nitrous. I hope you get your car fixed up Krsten. Youve been having bad luck wiht her this past year or so.
            01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
            AR stage 3 heads/intakes to be installed
            www.cardomain.com/id/firehawknwv
            www.vaperz.com
            PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
              Her car blew up twice because it was set up improperly. As a matter of fact, every mishap I've seen that's occured from nitrous is always because whoever installed the kit cut corners. Do everything right and don't skip steps/procedures, and your car will be fine.
                Well that I was unaware of, but you are right in what you say. However, I sill wont run nitrous probably ever.
                www.vaperz.com
                  Meh...your loss. Nitrous is a great power-adder...It can offer serious gains in the 1/4-mile, doesn't hurt your MPG if it's in your DD, and it only comes in exactly when you want it too. The only reason it has a bad rep is because of movies like FnF and people who try to get away with taking shortcuts and skipping procedure.
                    This is what dry kits are far.
                    Camaro V6 - 14.3 @ 96mph
                    Camaro SS - cam/boltons/m6/tune
                    http://www.crfhq.com
                      Ok well I dont want to steal her post here guys so lets turn it back over to Kristen.
                      www.vaperz.com
