Painted vs Ceramic Coated Headers - FirebirdV6.com/CamaroV6.com Message Board
  • Painted vs Ceramic Coated Headers
    will standard paint finishes on headers "burn" off eventualy? I want good looking headers on my Firebird, unlike the crappy rusted out exhaust manifolds...will the paint finishes eventualy rust out or burn off even with wrap on them? or should i just bite the bullet and fork out the extra 100 for ceramic coated headers?
    Re: Painted vs Ceramic Coated Headers
    Standard paint will eventually burn away. Ceramic coating will burn away too, just at a much slower rate. stay away from header wrap. They can trap moisture against the header, and promote/accelerate rusting
      well the painted will rust faster but if your wraping them does it matter??? coated headers will cut down on engine bay temps and keep the heat in the exhaust gases ( hot gases flow faster). But painted headers are just as good as the coated but if you going for the look of them get coated.
        coated headers will keep in heat better? or did you mean wrapped headers? well if im gonna wrap the headers does it matter if it traps moisture or not and corrodes the coating? cause they will be wrapped and it wont be seen.
          yes coated headers keep the heat in but like smoke said Im not sure of this but it makes sence that if the pipes are wrapped it will rust faster and maybe promote Leaks. So if you want the look get coated, if you dont care then the painted ones are fine.
            The coating lasts longer than paint and helps keep engine bay temps down among other things.
              Thanks a lot for your input guys. Im most likely gonna just suck it up and drop the extra 100 bucks for coated headers. Thanks again.
                The main thing the ceramic ones do are keep the underhood temps WAY down which is DEF worth it, i just bought some ceramic coated pacesetters and im waiting on some abbot gasekts but thats what i know
                  ok, wording that strong needs some sort of phsyical proof outside of what's listed in the ad for coated headers
                    haha ^^^. FYI the paint that comes on the Pacesetter headers is **** IMO. if youre going that route you might as well sand it off when you get em and repaint em with high heat engine paint
                      does high temp paint do good in the winter? I live in Indiana and I need something that will last through winters and rain. I'm thinkin the way to go is ceramic...so expensive though...
