header install done. - FirebirdV6.com/CamaroV6.com Message Board
  • header install done.
    it took 9-hours but its done.
    like the write up advised the longest part was takeing of the stock maifolds
    a oil flush-change was also done
    the car sounds great i luv it i did notice the egine-bay and engine temp is alot hotter:cool:
    is this normal
    any way i will post vid soon i just need to find out how to post it?
    Re: header install done.
    is this normal
    no. You probably have an exhaust leak somewhere
    upload it somewhere on the internet that hosts media files
      but how do i put it in the computer from the camcorder(mini dvc)
        firewire cable
          yea i googled it i dont think i have one-----------yet
            I just got my headers on also, i paid to get mine installed and it took them probably 7 hours to do it and it cost me $380 =( oh well it sounds AMAZING!!! Between the headers and the new high flow cat im set!!!! I noticed the engine seemed a lil bit hotter at first but not so much anymore, i need to go in tom and re tighten the bolts. Did you notice a clicking noise when you accelerate now??? I dont think its normal cuz it didnt make the noise before so i dont know if its something with the belts or what not but it only makes the noise when i accelerate...any ideas guys?
              exhaust leak...
                i had a leak at the stock cat and stock s pipe i got that changed to no cat 2.5'' pipe up to the cat-back welded (:D i luv it)
                but i did notice the clicking i hear it from the header on the left side
                i thought it was the cylinder's makeing that sound but maybe it is a leak
                after i got the new pipe my temp is back to normal.
                  yeah the clicking noise is on the left side only...any ideas for me and mike????
                    its an exhaust leak. check the flange and make sure they didnt break off any studs
                    1997 Camaro LS1 RS
                    1994 Camaro - Sold
                    1999 Trans am Vert - Sold
                    A Few Mods....
                      like i said twice before in this thread, you have an exhaust leak
                        I get that noise from the left when I start the car, I think it's just the egr blockoff though, did that on the tubie manifolds to.
                        Camaro V6 - 14.3 @ 96mph
                        Camaro SS - cam/boltons/m6/tune
                        http://www.crfhq.com
                          left side being drivers side?
                          if so, my money is on the EGR. clicking is definatly an exhuast leak and odds are its at the EGR. start the car, and feel around for exhuast. dont do this when the car is hot, let it sit for a while and start it up, it'll take a while to get hot anough to burn yourelf bad.
                          i noticed NO extra heat in the bay, nor are my temps any higher than before.
                          also, keep checking the Y pipe bolts. my header bolts BARELY loosened up, but my Y pipe bolts loosened alot for a while. check them every week or 2.
                            did you use cooper RTV, i used it on the intake side and the exhuast side and it works perfect. you can try just running a little bead around the plate maybe and see if it helps.
                              I've heard for the egr to header connection to use an egr gasket.
                              Does anyone know if this will work? Its from a 95 3.4l camaro
                              Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
