EGR leak??? - FirebirdV6.com/CamaroV6.com Message Board
EGR leak???
  • EGR leak???
    So the only problem i have had with my headers since i got them on last week is a mysterious clicking noise just on the left side when i accelerate, ive heard people having leaks with their egr with the pacesetters, so im thinking it might be that,SO i think im going to put some high temp sealent on the egr valve, will that do it?? Im also going to check the flange bolts also to make sure they are tightened.
    Re: EGR leak???
    This is the problem everyone here has, in my car, the problem is with the EGR hose connected to the header. If it is not fitted well, high temp sealent won't do the work, or that's what happened to me...
      Re: EGR leak???
      So what did you do to fix it, cuz the clicking noise is quite annoying
        Re: EGR leak???
        i ended up just blocking it off.
        try some copper RTV. let it set over night if possible, the stuff works GREAT.
          Re: EGR leak???
          I"m thinking about welding it up, mine leaks like a mother!
          MSN: inynn666@hotmail.com<br />1996 Arctic white -3800-<br />Pacesetter Headers & Y-Pipe, CAI, LS1 Dual Exhaust, LS1 Driveshaft<br />*15.17 @ 95MPH*
            Re: EGR leak???
            I use no gasket and RTV. Every once in awhile it blows out and I have to replace the RTV, but the current seal I'm on has lasted 6 months already.
              Re: EGR leak???
              i couldnt keep it sealed. we tried making a gasket and putting it in and then covering it with RTV... that blew out too.
              so i just went to gmpartsdirect and got a new tube, so hopefully i'll be able to get it sealed up.
              apparently the LT1 gaskets work better.
              2002 SOM Camaro- Sold
              2006 S60- Sold
              2000 Cherokee- The desert whip
                Re: EGR leak???
                I've had the best luck with no gasket. I tried stock and LT1 with and without RTV but gasketless with RTV really worked the best.
                  Re: EGR leak???
                  yeah, that makes sense. im sure it depends on the size of the leak though. mine was REALLY off, so the rtv just isnt able to hold. the gap is so large that the air automatically blows the rtv out.
                  2006 S60- Sold
                    Re: EGR leak???
                    alright well i have some high temp rtv sealent so ill have to give that a shot and see what i can do
                      Re: EGR leak???
                      i have the same problem i just got my headers done and that clicking is getteing to me i know i have a egr leak because i can feel the exhaust blow out of the egr i will try to fix it if i cant i will have to delete it... :twak:
