So the only problem i have had with my headers since i got them on last week is a mysterious clicking noise just on the left side when i accelerate, ive heard people having leaks with their egr with the pacesetters, so im thinking it might be that,SO i think im going to put some high temp sealent on the egr valve, will that do it?? Im also going to check the flange bolts also to make sure they are tightened.
EGR leak???
Re: EGR leak???
Originally posted by 97iastatecamaroSo the only problem i have had with my headers since i got them on last week is a mysterious clicking noise just on the left side when i accelerate, ive heard people having leaks with their egr with the pacesetters, so im thinking it might be that,SO i think im going to put some high temp sealent on the egr valve, will that do it?? Im also going to check the flange bolts also to make sure they are tightened.
Re: EGR leak???
i ended up just blocking it off.
try some copper RTV. let it set over night if possible, the stuff works GREAT.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: EGR leak???
I use no gasket and RTV. Every once in awhile it blows out and I have to replace the RTV, but the current seal I'm on has lasted 6 months already.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
Re: EGR leak???
i couldnt keep it sealed. we tried making a gasket and putting it in and then covering it with RTV... that blew out too.
so i just went to gmpartsdirect and got a new tube, so hopefully i'll be able to get it sealed up.
apparently the LT1 gaskets work better.2002 SOM Camaro- Sold
2006 S60- Sold
2000 Cherokee- The desert whip
Re: EGR leak???
I've had the best luck with no gasket. I tried stock and LT1 with and without RTV but gasketless with RTV really worked the best.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...1 hour ago
