egr leak is no more - FirebirdV6.com/CamaroV6.com Message Board
egr leak is no more
  • egr leak is no more
    so ive head an egr leak for a LONG time. it started after i had my headers installed. it started off as a small little leak, and then slowly blew out the whole gasket and was huge. i tried using RTV to make a new gasket, but it kept blowing out every time. then, white95 on here helped me out and used gasket paper to make a new gasket, and then coated it with rtv. this sealed it up for a bit, but it blew out again.
    SO. i ordered the lower tube assembly from gmpartsdirect ($42 shipped or something). we got it put in, and the problem is gone! basically, it is NOT the gasketed area that seals the egr tube to the header. it is the little tube itself. once the two parts get separated, you really cant re-use the same tube, because it wont fit in as well as it did the first time, and you will be left with a leak.
    i have pictures that i will get up asap that show what im talking about.
    2002 SOM Camaro- Sold
    2006 S60- Sold
    2000 Cherokee- The desert whip
    Re: egr leak is no more
    Yeah get some pics up or something cuz i have the same leak and i put some rtv around the outside and it seems like it might be working but i might need to add more or get whatever you got
      yep that was my issue too, the egr tube gets bent and wont seal good. i just got block off plates becuase id rather not have the egr system anyway.
        i had the same leak but i used orenge rtv high heat and so far im good i put lots of it im jus hopeing it stays good :cool:
          Yeah i put some on too right where the leak was and the air revented around the silicone to the sides so i just need to put sealent around the whole egr, its a lil quieter clicking now tho. Im going to the track tom night to see what i can run im pumped
            Would a possible remedy be to wrap the EGR tube up after spreading some copper RTV over the whole tube? Just an idea... I'm about to do my headers in about two weeks, and I'm a little nervous about the whole EGR thing considering I've heard horror stories about it. In any case, thanks for the tip! It may come in handy down the road.
