So i took my car to the track after i got my full exhaust done from headers to highflow cat and catback and my times werent as good as last time when all i had was catback. it was warmer last night than a year ago when i went. Could the egr leak cause a power loss or is that ticking just not matter. I might need to clean my fuel injectors also its been a while since I have i think you just buy the **** and poor it in
EGR leak power loss?
Re: EGR leak power loss?
it was probably the temp difference. But you can just get some type of filler to fix that anyway, i know mine got really bad and it was really really really anoying till i used tome jb weld on the *****
false KR\'97 Camaro M5 Y87 3.23 LSD, homebrew CAI, highfloCat, Flowmaster catback, Pacesetter headers, specstage3 clutch and aluminum flywheel, !egr, 2kW system.<br /><br />Possible L67 bottom end w/ abbott heads and a turbo in the works... gotta do more homework
