Hey guys. I had a muffler put on Predator bird to hush it down a bit and it worked beautifully. Trouble is now i can hear another exhaust related noise. When the characteristic rough idle comes and goes I can feel the drivers side header or possible the pipe coming off of it hitting or rubbing something under there. Im assuming the k member but i havent really dug into it deep enough. I can hear it and also feel it in my feet from the floor. I was going to dig into it this weekend and see if i can bend or adjust something but my question was have any of yall had this same problem before? Thanks in advance guys :)
Anyone else with pacesetters on your 3.4 have rubbing issues?
Re: Anyone else with pacesetters on your 3.4 have rubbing issues?
Originally posted by RedGSHey guys. I had a muffler put on Predator bird to hush it down a bit and it worked beautifully. Trouble is now i can hear another exhaust related noise. When the characteristic rough idle comes and goes I can feel the drivers side header or possible the pipe coming off of it hitting or rubbing something under there. Im assuming the k member but i havent really dug into it deep enough. I can hear it and also feel it in my feet from the floor. I was going to dig into it this weekend and see if i can bend or adjust something but my question was have any of yall had this same problem before? Thanks in advance guys :)
Originally posted by SpeedingFirebirdyep. The Y-pipe driver's side rubbed on the subframe. We fixed it by heating the bejesus out of the subframe and beating it. We reshaped the subframe to move it, oh about a quarter inch for the Y-pipe to clear.
Update: I went yesterday to the muffler shop again and sure enough there was a raised spot on the pipe that has been rubbing on the subframe so a little heat and some ingenuity and its all well again. Thanks for the advice :)
what muffler did you put on there? did you just replace the bullett or the whole rear section?94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
Originally posted by Predator Birdwhat muffler did you put on there? did you just replace the bullett or the whole rear section?
It has a muffler in the factory location now with the drivers side b&b tips coming off of it. The bullet is still on there and everything from the axle to the front is untouched. I could have put the other side on as a dummy set but i decided not to. Its in the garage in case i change my mind. I wasnt too disappointed since i like the firehawks with the tips coming out the drivers side only. Between the muffler and replacing the dash, its as quiet as a caddy now :p
single b&b tip :cry: maybe you could do a borla style setup and put a block off plate in the pass exhaust pipe and run the exhaust through the muffler on the driver side. just a suggestion.94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
