how long have you had this combination and does it now leak? thanks!
anybody with pacesetters and abbott racing gaskets.....help
Re: anybody with pacesetters and abbott racing gaskets.....help
I've had mine for about a month and a half and they do leak some. BUT, I still haven't gotten under there and retightened the bolts, so that should fix it once I get it done.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
as long as you are checking your bolts a couple times for the first couple weeks there will be no issues with them. People that have issues with them leaking are the ones that tighten them the first time then forget to do it for a couple weeks and then run into problems.
Usually the EGR is the biggest culprit for leaks with these headers
Originally posted by 97rs4lifeas long as you are checking your bolts a couple times for the first couple weeks there will be no issues with them. People that have issues with them leaking are the ones that tighten them the first time then forget to do it for a couple weeks and then run into problems.
tighten all the bolts and see if it still leaks. ive had no issues with my abbott gaskets.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
i re-used the stock gaskets first and had leaks. Switched to Abbott and no problems. Have had them on for ~6,000 miles. Still have an EGR leak that I have been trying to fix. I am actually going to use some exhaust sealant tonight and see if that fixes it.2002 Camaro A4<br />K&N FIPK<br />Ravin exhaust<br />15.64 @ 90.11 MPH<br /><br />_ _ ___________________ _ _ <br />2004 Quicksilver/Black GTO M6<br />Stock except !CAGS
