Throttle Body Spacer - FirebirdV6.com/CamaroV6.com Message Board
  • Throttle Body Spacer
    are the Throttle Body Spacers really worth buying? there is one here for about $100, and claims to give 10 hp & 12 torque
    http://www.autopartswarehouse.com/pe...1999&partid=22
    does this part actualy work or is it a rip off?
    Re: Throttle Body Spacer
    yeah i've got one and no i don't think it gives you 10 more HP but it does make you intake sound wicked
      there are a few other things i'd get first... what mods do you have?
      Welcome future UK stars... Darius Miller, Deandre Liggins, Kevin Galloway, Josh Harrellson
        is 99 a straight TB? if not go to summit u can get one cheaper
          99 and up is straight, 98 is angled
            There is no way that a carb/tb spacer is going to give any engine 10 hp. Sorry but at best I would expect to see is a 1-1.5 hp gain anything more would be great.
              tb spacers are for when you have done everything else you can do to the engine and after that you might need one
                not worth it at $100. If it was 40-50 it would be alright to get it as a last mod
                http://www.bowtiev6.com/
                  $45 from zzp. And it's phenolic so it doesn't transfer heat like a metal spacer.
                    yeah it does seem a little expensive. i have a ram air kit, air box lid, jet chip, and muffler so i was looking for some good hp before i replaces the entire exhause with headers and cat back. is this a good next step if i can get one for $45? or should i get something else? it's a 99 camaro
                      Get something else.
                      Raven
                        what? short throw shifter?
