MAF Screen - FirebirdV6.com/CamaroV6.com Message Board
MAF Screen
  • MAF Screen
    I know, I know. You're not supposed to take it off for pre-98 cars. But, I did. I was going to tap my TB for my nitrous nozzle the other day, and realized the only tap that I didn't have was the one I needed (damn 1/16 tap :rant: ). So, I go foraging (sp) in our shed for one. Never found one, then look down and realize I had to be at work in about 20 minutes (15min drive), so I hurried and changed and put the intake back together w/out the MAF screen. I figured I'd have to take it out anyways when I do tap it, so I'll leave it out until then. Well, all the rumors I've heard about surging, rough idle, constant stalling, etc wasn't the case for my car. I cranked it up and all was fine:). I'm still running with no MAF screen (day 4 now), and none of that has happened. However, I did notice abit (just a tiny bit) deeper exhaust sound. I'll borrow my Uncle's scanner sometime and see what the MAF reads with it out, then pop it back in and see what it reads to see if it really does help the MAF or not. I know most of you guys are going to say I should put it back in. I don't know if it's because of my intake (Moroso LT1 CAI, intakehoses.com reducing 90* elbow, and a 3" coupler), or if my car's just an oddball. I'm keeping it out until I get a chance to get my nozzle installed, and who knows when that will be.
    Just figured I'd throw this out there. Maybe the pre-98 cars should give it a try? If I get a chance to check the MAF reading, if there's no difference in the readings, or it's better with the screen, then it's probably going back in. Otherwise, it'll probably stay out.
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
    Re: MAF Screen
    took mine out a long time ago, and havent looked back sence
      Re: MAF Screen
      Same thing here. I took mine out months ago, and have had no problems. Mine was all messed up too, so I'm sure it didn't help airflow too much.
      Representin' Team Red In The North
      Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
      Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
      Black/Red '02 Honda CBR 954RR Fireblade
        Re: MAF Screen
        my car, even with the straight tb, hated me after I removed the MAF screen
          Re: MAF Screen
          In theory and on paper there are good reasons to keep it, but on my LT1 i ran without it for nearly two years without any problems
          also, kind of comparing apples to oranges, but in an LS1 its been proven that (with tuning), removing the screen gives you up to 5rwhp
            Re: MAF Screen
            I think the question that has always been at hand is: is it really worth taking it out?
            Oh, and I looked at mine the other day, and I know people have destroyed them while getting them out with the screwdriver/sharp device... I think all you would need is a pair of snap-ring pliers... Might just be me seeing things though. I might take mine out of my '99 one day if someone can prove that it actually does something. I mean, why would GM put it there in the first place?
              Re: MAF Screen
              why would they put 2 useless engine lift brackets on the car, over the valve covers so that you cant get your covers off unless you take the brackets off.
              And the brackets are completly useless
                Re: MAF Screen
                that's good, but a lot of places that dyno tune LS1's won't even touch them with the screen removed
                  Re: MAF Screen
                  Snap ring pliers are how I got mine out. My reason for not putting it back in is that I lost the c-clip. :D
                    Re: MAF Screen
                    Haha... those c-clips can have quite a bit of tension on them. The only time I've used them is when putting the BOV on my buddy's SR20 240. They're a bia to work with.
                      Re: MAF Screen
                      That's all it takes. I got some snap-ring pliers and pulled the clip out, then used them to pull the screen out too :P
                      My car's a 97 BTW
                      ~97 3.8L V6 Camaro~
                      A few things
                        Re: MAF Screen
                        Yeah I haven't had mine in on my 96 for about a month now and it runs fine and the exhaust tone is slightly deeper
                        1996 Silver Camaro RS, A4, K&N CAI, Flowtech exhaust, !MAF screen.
                        http://www.fquick.com/96silverbullet
                          Re: MAF Screen
                          Mine has been out since Ive owned it (Feb)! I would say the problems you stated are from a damageed IAT. I forgot and left mine out once and that was its symptoms. But I just put the IAT back in and all has been well ever since. I would have put it back in but I killed it with a screwdriver like most other ppl! Btw; Its a 2000 Bird...
                            Re: MAF Screen
                            See, with the 99 and newer cars, they don't have the angled TB. Supposedly the screen helps straighten the incoming air for the angled throttle bodies and with it removed the MAF doesn't get an accurate reading and the car ends up not running right.
                            ~97 3.8L V6 Camaro~
                            A few things
                              Re: MAF Screen
                              Well if I find mine from the 99 camaro Ill give it to you. And I believe I still have the ring from the bird. :tup:
                                6 days ago
