side exit exhaust - FirebirdV6.com/CamaroV6.com Message Board
side exit exhaust
  • side exit exhaust
    i have a couple of questions for u exhaust gurus. im planning on doing side exit exhaust on my car. thinking of a flowmaster and i want the exhaust to exit behind my doors infront of the back tires. my setup i was planning was a flowmaster 80 series with bowtie tips behind the doors. my question is does the heat from the exhaust effect the back tires? i have vette wheels on my car and will the exhaust leave black smoke on my wheels? how about clearence?
    Re: side exit exhaust
    clearence would be pretty much your only problem
      Im planning on doing that for my exhaust so ill let you know how it is :P
      WE CAN REBUILD IT, WE HAVE THE TECHNOLOGY
        Well Pathogen (jenn) over on FTv6 did true dual side exhaust. both going to the Passenger side
          this would be sick. lets see some pics when completed. or if anyone can find any. :]
            yes she did, but the way her True Duals are made, it would be highly unlikely you could find a shop to do this.
              well i went to many exhaust shops and they said they couldnt do it cuz the exhaust would hang to low and the flowmaster 80 series is to big and theres no room under there to put it. so i just went with what everyone is does and put duals out the back with square camaro tips. also they took off my cat and its sounds OK not the tone i was lookin for. imma try a diff setup and see what happens. maybe put a cat on it. i guess u cant really make the v6 sounds deep without installing cam and other mods.
                well if the exhaust shop here does not let me do side, then I will guage the price of having it put over the axle. now you said they took off the cat.. on true duals? thats stupid. when true duals are put on our car, unless you have a blower or cam you want all the backpressure you can get. Also did you have an H or X pipe?
                  you dont need back pressure, thats a myth, and he didnt get true duals im guessing, just single in dual out
                    The exhaust shop that i went to said they couldnt even screw with a catalytic converter besides put a new one on otherwise there is a hefty fine if they get caught. They said the fine was about $10,000 so they werent going to screw around with my cat.
                      thats true :P thats why the ones that will take of your cat.. you wont be getting a receipt :P
                      also if a cop looks under your car and you dont have a cat, and they are ****s, they will slap you w/ a nice $1500 fine..
                      thats also the reason i will be buying 2 highflow cats, eventually XD
                        just gut out your cat :)
                        sucks for you guys though, i run catless and i passed emissions just the other day lol
                          nah i got a receipt and on there it says removal of cat. i guess in Texas they can remove it, but i do know that alot of the inspection places check to see if u have a cat. and no i ddnt install true duals. i did flowmaster 80 series(1 in 2out). it sounds ok at low idle but when i get past 3k it sounds ****ty. and u dont need back pressure its just a myth like someone mentioned. i think theres a thread on here or fullthrottlev6 about that.
                          Meatyshells- im with u on running catless. the place where i get my emmision tests here in texas doesnt check anything.
                            okay backpressure is a myth when the set up is right. if you have enough power to support having completely free flowing exhaust (with true duals) then backpressure takes no effect.
                            but other then that, backpressure is sure as hell not a myth.
                              dude, ever since this stupid kid took his srt-4 and put side pipes on it I have hated side pipes.eckckkkk
