is it possible to take the whole exhaust off without cutting anything?
Re: is it possible to take the whole exhaust off without cutting anything?
You don't have to cut the pipe over the axle. You need to unbolt your pass side rear shock, and pull the spring, then pull the rear down far enough. I removed the stock catback from my 00 Formula in one piece this way!
Very true. I just wanted to keep my stuff in one piece since my car was an NHRA edition and 1 of like 200 made. For a stock V6 exhaust, i'd cut it and band clamp it!
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
