is it possible to take the whole exhaust off without cutting anything? - FirebirdV6.com/CamaroV6.com Message Board
  • is it possible to take the whole exhaust off without cutting anything?
    on a 97 camaro or 98 firebird..
    if i unbolt the headers and jack the rear up high enough.. would it be able to be pulled through?
    and are those 2 cars interchangable? could i take the exhaust off the camaro and put it on the firebird?
    Re: is it possible to take the whole exhaust off without cutting anything?
    No. You'd have to drop the rear axle if you wanted to do that
    yes
      yeah you have to cut the over axel pipe, but i believe that is it
        You don't have to cut the pipe over the axle. You need to unbolt your pass side rear shock, and pull the spring, then pull the rear down far enough. I removed the stock catback from my 00 Formula in one piece this way!
          would be 10Xs easier to just cut it lol. But i guess if you have to get it off in one piece
            Why would you even want to save a stock exhaust?
              Very true. I just wanted to keep my stuff in one piece since my car was an NHRA edition and 1 of like 200 made. For a stock V6 exhaust, i'd cut it and band clamp it!
