Problem and an upgrade - FirebirdV6.com/CamaroV6.com Message Board
  • Problem and an upgrade
    Ok, i'd like to share both a problem and an upgrade in the works, all your oppinions are most welcome.
    Firstly I have a K&N cold air intake system. Not just the filter, but the whole thingie going down in the box front of the wheel. I am not sure why they call it cold air intake, I'm seriously under the impression it's more of a "warm" air intake than anything else.
    In the morning when I start my car, it has quite a good response, power and torque. Approx 5-10 minutes later, as soon as the engine warms up a bit, there is a sudden power drop of (juding by feel) about 30%. There's a noticable lag after pushing the gas (with a shuuup noise before reaction) and the rpm going up. Like there's a sudden vacuum in the intake or something.
    My only thought this far about this problem is that the intake takes warm air as soon as the engine warms up. When I look now under the hood, the intake airfilter is clearly in an enclosed plastic corner close to the engine. It makes sense the air there is quite warm.
    So i've decided to try the following:
    The front 2 wholes on the bumper are useless now
    They will be turned into air intake corridors, both lines with a separate airtube, united before the engine's air filter and directly into the engine.
    This will allow for real cold air to go into the engine directly, without it being warmed by the engine, constraint by a small encaptioned space etc.
    Has anyone tried this before and what do you think ?
    Re: Problem and an upgrade
    i've seen it done before....
    tho on a 98+ camaro i believe. think it helps just a TAD more.
    '95 3.8L A4 PGM. & '95 LT1 M6 PGM. :burn:
      to tell you the truth i don't think that this is your problem. i mean if you think about about it, i'm sure that it does the same thing on a morning where it's 30 degrees out and the same thing when it's already 80 degrees out. so the temp would already be warmer.
      cutting the holes would give your more air flow. i just did this a few weeks ago to my camaro. i don't feel any difference. then again she only drove about 20 miles since then lol.
      WAWA-A-HOLIC
        go for it... I mean it won't hurt, but don't put too much effort into the intake as of right now. If you mass mod the car then you can worry about the intake more. The filter and relocating the air induction is good enough for now.
          But did you just cut holes so that more cold air would reach the engine compartment or did you make complete airtubes from the holes to the engine intake ? I'm actually expecting quite a difference from this.
          If this would not be the reason for the power drop, any other ideas ? Actually I think it really makes a difference how warm the day is. For example in the morning when I'd go to work - it's very noticable. A lot more power and better response. If I'd start the car around noon or 14h, the difference is less noticable and the low power state is reached faster.
            i just cut out the holes cause it was ugly with my slp grill :)
            it could be any number of reasons. have you had your car on a computer run to see what she is doing.
            WAWA-A-HOLIC
