So yeah, I was wondering if there might have been a write up or any simple ideas with stabalizing the flowmaster 80 series catback. That thing is just too loose for me and if I turn hard enough.. which isn't much it bangs against the body. I haven't crawled under it yet trying to figure out a solution so before I do I was just wondering if anyone has already thought about this and came up with anything. And if not lemme know too cause I suppose if a lot of people might have the same problem then I'll do my own write up when I get around to it. The hanger setup is just too wobbly, almost like that rope bridge in The Temple Of Doom. Ya know? Indy?
Wobbly unstable flowmaster catback stock hangers
Re: Wobbly unstable flowmaster catback stock hangers
Originally posted by Smoke PantherI'm willing to bet that it's a broken hanger on one side...kneel down and take a look, it really isn't that hard. If that's the case, just go to autozone or something and get a replacement.
None of the hangers are broken, that'd be the first obvious thing that I would look at. It just sways a lot from the rubber brackets. It always has ever since I installed it. I'll do somethin with it, I'm just suprised it's not a common thing since it was installed correctly and nothing is cracked broken or loose.. Besides the whole damn thing being loose.
TEAM C6V6
No no no, u guys got the wrong idea. i know just what u speak of there blizzy. My shiz has be givin my grief just like u. the first thing i did was unbolt one hanger from a one side. if you look at the metal piece it has a total of three prongs. does it? this is what i did:
i stretched the rubber piece between two prongs and left one bare. to do this, u have to cut the prong that does not have the stub on its end. cut the prong at an angle just enough to stretch the rubber overe the cut metal prong. then, this can be used to put the exhuast hanger through the open section in the mddle of the rubber hanger, on the bolted hanger. bolt the body hanger back on with the exhuast all ready fitted to be hung by the rubber piece. bolt it back the the car and do the other side.
this worked for me for a while, u might want to try this.
it worked for a long time until the rubber weakened and just wasnt doing the same effectiveness.
after a lil over a year, i intalled metal sheet hangers using my welder to stabilize the muffer from bouuncing up and hitting the body.
flowmaster muffler is quite heavy. i hate this frikin muffler. i will never buy one again. mine has already rustyed out inside, and rattles insanley, drives me nucking futs.
Good luck to youHeady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
Heh, thanks heady. I was hoping someone understood. And as for a muffler shop.. screw that, I can weld. :banana: But I may come up with a cheaper easier solution just to contribute. I'll be able to put my camera to work for a good cause.
TEAM C6V6
imo i deff wouldn't get it welded. i can't tell you how many times i was doing mods to my car, where i had to drop the exhaust.
i had the same problem, i got 2 new rubber exhaust hangers from gm. i was suprised how worn mine where. took care of my problem.
Originally posted by kristenimo i deff wouldn't get it welded. i can't tell you how many times i was doing mods to my car, where i had to drop the exhaust.
TEAM C6V6
Originally posted by Blizzard242So yeah, I was wondering if there might have been a write up or any simple ideas with stabalizing the flowmaster 80 series catback. That thing is just too loose for me and if I turn hard enough.. which isn't much it bangs against the body. I haven't crawled under it yet trying to figure out a solution so before I do I was just wondering if anyone has already thought about this and came up with anything. And if not lemme know too cause I suppose if a lot of people might have the same problem then I'll do my own write up when I get around to it. The hanger setup is just too wobbly, almost like that rope bridge in The Temple Of Doom. Ya know? Indy?
Sounds like you have the 98+ hangers, which are JUNK. The 93-97 hangers are completely different, and far better in my opinion.Last edited by FirebirdGT; 11-25-2007, 11:16 AM.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by FirebirdGTSounds like you have the 98+ hangers, which are JUNK. The 93-97 hangers are completely different.
TEAM C6V6
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 hours ago
