I installed a set of pacesetter headers a few months ago and i have been fighting with the egr connecton eversince. the gasket included in the set lasted about a day. after that i have been trying to seal it up with red high-temp silicone gasket maker. the metal tube from the egr valve base fits into the headers fine but i cant get it to seal around the top. any suggestions???
EGR leak
Re: EGR leak
I have the EXACT same problem...i have made the part to fit exactly with the header, but I think it is still leaking around the top due to the lack of a top bolt. Now, I have striped the bolt so I can't remove the EGR tube anymore. This has been going on since the beginning of summer, and I was about to put the red exhaust repair stuff. I am really really getting fed up with it.
Wil the EGR simulator allow you to pass emissions?2002 Camaro A4<br />K&N FIPK<br />Ravin exhaust<br />15.64 @ 90.11 MPH<br /><br />_ _ ___________________ _ _ <br />2004 Quicksilver/Black GTO M6<br />Stock except !CAGS
Re: EGR leak
Originally posted by JumpInTheFire.comwhen the egr leaks..what happens? does smoke blow out of it?2002 Camaro A4<br />K&N FIPK<br />Ravin exhaust<br />15.64 @ 90.11 MPH<br /><br />_ _ ___________________ _ _ <br />2004 Quicksilver/Black GTO M6<br />Stock except !CAGS
Re: EGR leak
copper rtv usaully works well. try that before you delete it, deleting it has its draw backs.
but FWIW mine is deleted.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: EGR leak
Originally posted by MIKE1stcamv6also engine bay temp's in my case went up
the sim does not let the car trow any codes. some people like the cleaner look i was sick of the leak:spank:. are pacesetters the any ones with this prob??
i think ive heard of people having to trim the egr tube to get it back in the header too. i dont know what exactly everyones issues are.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: EGR leak
just do the efr delete and save yourself alot of time. zzperformance.com they are like 5 bucks each. take your egr valve out, put on block on the upper intake and on the header with gasket maker. bam your done. if you need it for inspection. out the valve back in that day. and just leave the one on the header, but cut the edge of the header tube (tube that goes from the egr to the header) off and just make a sandwich with the block off still there. they won't even notice it.
Re: EGR leak
Originally posted by screamin 99so is there a drawback to deleting the egr I'm not worried about passing emissions(we don't have them:rock: ) will it run alright with the egr simulator?
It may ping at part throttle cruse in overdrive. People with larger than stock cams would not see this due to the cam lowering the cylinder pressure at lower RPM cruise, just as the EGR would do. The PCM puts close to 40* timing during low RPM cruise.
Briansigpic
