If you have them ware did you get them and how much did you pay?
3.4 headers
Re: 3.4 headers
http://www.lmperformance.com/3342/14.html Be ready they are not the easiest things to put on. If you take it to a shop to do it will be pretty expensive. I got estamated anywhere between 300 to 400 dollars just to install them not even including the headers. Here is a nother place you can go. http://store.summitracing.com/egnsea...115+4294840048 Also be carefull if you do it your self not to break a bolt. Then you have your self a whole nother set of problems.
Re: 3.4 headers
RK Sport, $500 I think. I'm actually very happy with them. The tubes are 14 guage steel. The flanges are nice and meaty so they don't leak, plus their ceramic coated. They've been on my car for almost 2 years and look like the day I bought them. Only down side is to bolt the passenger side header in you have to heat up the frame and pound it in with a hammer or the header will vibrate on the frame and get really annoying. Oh also the EGR mount on mine broke because it's not strong enought to hold the tube and valve, I just blocked it off.
I used stage8 bolts to keep them from loosening up, and copper collector gaskets to keep them from leaking. If I get a chance I'll take pics this week and post them.
Other than the EGR mount and passenger header clearance, I'm very happy with them.
