Is is possible for snow filled exhaust tips (snow PACKED exhaust tips, actually) to cause an engine fire? How about in conjunction with lots of free revving/ wheel spinning?
exhaust restriction causing engine fire?
94 Camaro convertible -- mostly stock
97 Firebird -- Project Car - kyb agx shocks, eibach springs, 3.42 torsen diff, aluminum driveshaft, slp cai, pacesetter headers, magnaflow cat-back. hptuners. not done yet.
98 Firebird -- Parts Car
Tags: None
Re: exhaust restriction causing engine fire?
well my brother's engine caught on fire the other day and I noticed his exhaust tips were packed full of snow. just wondering if that could have been the culprit94 Camaro convertible -- mostly stock
it could definitely aggravate a problem, but i doubt it was the primary cause.
can you tell what caught fire, or where in the engine compartment the flames
were at? or did you just see a bunch of smoke?
An engine will not run if exhaust pipe is clugged up.
Dirty trick we use to do to people we didn't like in early teenage years.
Take a regular potato and smash it onto a tailpipe as hard as you can so pressure won't blow it off....car won't start
