today i got into an argument w/ a guy who said a cai is the exact same thing as a supercharger. i told him there two different things but his ignuarnt *** wouldnt give. so the question is a cai the EXACT same thing as a supercharger???
A bet
Re: A bet
no.
Wikipedia has the perfect definitions, which you have access to if you have access to this site:
Supercharger: A supercharger (blower) is a gas compressor that forces more air and thus more oxygen into the combustion chamber(s) of an internal combustion engine than is achievable with ambient atmospheric pressure.
The additional mass of oxygen-containing air forced into the engine improves its volumetric efficiency, allowing it to burn more fuel in a given cycle and thereby produce more power. A supercharger can be powered mechanically by belt, gear and shaft, or chain-drive from the engine's crankshaft. It can also be driven by a gas turbine powered by the exhaust gases from the engine. Such turbine-driven centrifugal superchargers are correctly known as turbo-superchargers, or more commonly, turbochargers.
Cold Air Intake: A cold air intake is a system used to bring down the temperature of the air going into a car for the purpose of increasing the power of the internal-combustion engineLast edited by MAYH3M; 02-21-2008, 04:07 AM.
1998 Chevrolet Camaro SS
New Trans Setup:Rebuilt 4L60E, Yank ST2800 Stall, B&M Trans Cooler,
TCI Deep Pan, Royal Purple, Trans-go Shift Kit. Should be done in January.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...2 hours ago
