Leaking EGR - FirebirdV6.com/CamaroV6.com Message Board
Leaking EGR
  • Leaking EGR
    I recently put Pacesetter Headers on my 3.8L and everything was fine until recently. Now my EGR is leaking is there anything I can do to stop it.
    Re: Leaking EGR
    first go through all your bolts and make sure they are tight, they like to loosen up after a while. if that doesnt work pull the egr out and make a nice coating of copper RTV on the flange and that should seal it up
      Re: Leaking EGR
      seal it
        Re: Leaking EGR
        go to zzp and get 2 block of plates. put on the header and one on the upper intake! take the egr out(keep it) and then just put it back on when you have to go in for inspection.
        WAWA-A-HOLIC
          Re: Leaking EGR
          If I block off the EGR valve then what would i need to do to keep the pcm from throwing codes?
            Re: Leaking EGR
            delete the code
              Re: Leaking EGR
              i never saw a code
              WAWA-A-HOLIC
                Re: Leaking EGR
                Bad idea unless your going to have it tuned or only run premium gas. Not having the EGR will cause it to ping at highway cruse speeds with a stock tune.
                  Re: Leaking EGR
                  zzp also has a egr simulater i have it and it works no codes 6 months so far
                  :banana:
