What size? - FirebirdV6.com/CamaroV6.com Message Board
What size?
  • What size?
    What size is the stock exhaust pipe? I'm trying to find tips that'll fit. I've checked the specs apparently I really suck at measuring or math because what I've measured as the diameter and what I measured as the circumference are not on the same page.
    Of course I did almost fail geometry, but if memory serves the circumference is still pi times the diameter?
    Of course I don't know if it is actually stock...sure looks like it though. Is a little bigger around than a coke can.
    Re: What size?
    stock is 2.25" diameter. I believe GM used a coke can to determine what the F-body's stock exhaust diameter should be actually :D
    and yes, circumference is pi times diameter. geometry was a *****....
    1999 Firebird Y87/W68
      Re: What size?
      haha
      Thanks
