I have a 2000 camaro with the fly by wire set up and I wanted to get a throttle body spacer. I called summit to get one,they said that all the ones they had were for 99 down. I went ahead and got one anyway figuring it's the same. Am I right to assume this?
Re: throttle body spacer
Originally posted by fatcat View PostI have a 2000 camaro with the fly by wire set up and I wanted to get a throttle body spacer. I called summit to get one,they said that all the ones they had were for 99 down. I went ahead and got one anyway figuring it's the same. Am I right to assume this?
No. It's most likely for a FWD engine.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by fatcat View PostDo they make one for us? I thought I saw one on a thread but can't seem to find it. Could someone find the tread for me?
surprise, surprise...using the search query of "TB spacer"
Originally posted by fatcat View PostAre you sure? the one I ordered is on it's way and I have to accept it when it arrives so I need to know if I can use it.
Originally posted by fatcat View PostI did butI did throttle body spacer instead of tb spacer...oops. So the motorvation one from summit won't work on my car?
Originally posted by Bonemaro View PostNot to highjack or anything, but what does a TB spacer do?
http://store.summitracing.com/partde...5&autoview=sku
^here's my link. Instead of talking all this "it said this" and "it said that," just give us the link
EDIT: Also, when it comes to throttle bodies...anything that's gonna work on a 99+, isn't going to work on a 98- without modification...so, the fact that it was listed as fitting both, should have been your first clue to spend $80 on something worthwhileLast edited by Smoke Panther; 03-26-2008, 06:29 PM.
Originally posted by Smoke Panther View Postit makes your throttle body longer...basically, nothing
Not exactly...supposedly it suppose to separate the tb from the intake manifold...lowering the air intake temp.
I don't know about gaining any power...but it definately keeps the tb cooler than the super hot intake. My reason for using it is to keep the "electrontic" tb cooler...we all know heat kills electronics.
Originally posted by Christopherrr View PostNot exactly...supposedly it suppose to separate the tb from the intake manifold...lowering the air intake temp.
I don't know about gaining any power...but it definately keeps the tb cooler than the super hot intake. My reason for using it is to keep the "electrontic" tb cooler...we all know heat kills electronics.Last edited by Smoke Panther; 03-26-2008, 11:28 PM.
