on the stock air box lid can you just gring off all the Flanges to make it liek a whisper Lid
stock air bock lid to whisper?
Re: stock air bock lid to whisper?
why would oval be worse? seems like you would actually get more flow with an oval, especially since the oval has a much higher surface area, about 2.25 sq. inches more than than a circle, based on my rough estimating. Not that its going to make much difference....but remember that the V8 throttlebody is an oval.
basically the TALLER part is the only difference (and the important one). If it makes you feel better you could probably trim out the support bar in the port.
search the free ram air mod... there is a sticky somewhere with pics...
IMO its better then stock but the whisper lid is more what you need. If you look around you can find one pretty cheap. I got mine for like 70 dollars. You can see the difference between the stock lid sanded down compared.
Originally posted by zpwn06 View Postwhy would oval be worse? seems like you would actually get more flow with an oval, especially since the oval has a much higher surface area, about 2.25 sq. inches more than than a circle, based on my rough estimating. Not that its going to make much difference....but remember that the V8 throttlebody is an oval.
basically the TALLER part is the only difference (and the important one). If it makes you feel better you could probably trim out the support bar in the port.sigpic
TB is round, stock box is oval. Don't know about restriction but the straighter the shot with less transitiion or resistance the better.Let's flip a coin. Heads I get tail, Tails I get head.
Originally posted by youngsc View PostTB is round, stock box is oval. Don't know about restriction but the straighter the shot with less transitiion or resistance the better.
2)What matters in an intake is volume, not surface area.
3)Even if they mattered, your math is way off
^this is as simple as I can explain it.
^Do either of those look like an oval to you? That may be the case on the LT1, but the LT1 is an inferior motorLast edited by Smoke Panther; 04-16-2008, 12:30 PM.
Originally posted by zpwn06 View Postby the time you go through that much pipe, intake manifold ect, I'm not sure it matters that much.
volume seems much more significant.
If your worried about smooth flow, then those rubber collars ought to worry you a lot more.
On my 2000 it's lid, 3" tube TB. I'm pulling more air through with the hole I cut in the air lid base so it's pulling more air from in front of the radiator. Maybe on other cars it's going through tubes but on most it's a straight shot into the engine. The less restrictive and more uniform that path is the better.Let's flip a coin. Heads I get tail, Tails I get head.
