I have a 2bbl 2.8 v6, stock other than a K&N filter and I run a 3" pipe from the stock cat back and splits into two 3" pipes, no muffler just a splitter. It sounds good, a little loud maybe. If for example I am in overdrive cruising at 50mph, it is so loud inside the car I think my teeth may fall out:eek: from the vibration and I will surely suffer from hearing loss. If I drop the transmission into drive (3rd on a 700r?) from OD it sounds good again and just a nice rumble from the rear of the car. If I wait till I am out on the freeway to use OD it sounds good at 70mph. Anyone know what gives? What may be causing my discomfort and what I might do to fix it? Thanks Much!
Question on exhaust sound:
Re: Question on exhaust sound:
Originally posted by zpwn06 View Postprobably just resonates at that particular frequency.
Lounge Moderator
