can't pass emissions inspection (NOx) - FirebirdV6.com/CamaroV6.com Message Board
  • can't pass emissions inspection (NOx)
    i have a 95 3.4l v6 camaro, auto. it has a magnaflow/carsound high flow cat, with a flowmaster american thunder catback. stock manifolds. its also got a cold air intake.
    i went to inspection in early january. my NOx emissions were 1575, and it says the standard is 879. i went again today, my NOx emissions were 1428, standard 907. it passed the HC emissions both times by a large margin (35, with 117 standard.)
    the first time i took it it was on 87 gas and no egr valve. today it was on 93 gas and i put the egr valve back on.
    since ive put the egr valve on im noticing better fuel economy. but the valve itself leaks and makes a lot of noise.
    do i need a new egr valve or is something else wrong? also im almost positive i've passed inspection before with this exhaust setup, but at that time my egr was on and working fine.
    <a href=\"http://www.cardomain.com/ride/2265676\" target=\"_blank\">95 bright red camaro 3.4l</a>
    Re: can't pass emissions inspection (NOx)
    your egr gasket may be leaking
      obivously your egr, thats what theyre designed to do, but here are some other things you can try: sometimes if you drive one the highway a long time you can heat up the cat alot though not sure if that'll help with NOx. You could probably also take off your cai, and tape your IAT sensor to your radiator. If all that doesn't work, put a sock over your tb and secure with a hoseclamp. To avoid NOx you want the fuel burning at as low a temperature as possible, so warm, dry, restricted air.
        The EGR's sole purpose is to reduce NOx by lowering combustion temps. Better fuel mileage is a by product of it. Start with that. Make sure you take a long drive at highway speeds before your car is tested.
          My Hptuners stop working
          Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
          13 hours ago
        • Money pit
          Zzp cams
          by Money pit
          Has anyone used zzp gt1 cam if so is it worth the money and time
          2 days ago
        • thatpewterfirebird
          2001 3800 s2 firebird
          by thatpewterfirebird
          4 days ago
        • Turbo 3800 camaro
          Where are the videos?
          by Turbo 3800 camaro
          Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
          6 days ago
          New Chevele
          Just saw it on Facebook, looks awesome. The front and rear nice looking....
