ok so my question about o2 emulators is if you get one will it work to fool the sensor that is BEFORE the catalytic converter? and would there be problems if i were to take the whole exhaust off from the headers and put an o2 sensor for the one b4 the cat AND one after the cat?
o2 emulator question
Re: o2 emulator question
From what I understand the aftercat 02 sensor only checks for emissions, it doesn't actually control how the engine runs. If that sensor is bad, then it only throws a code, not actually effecting anything other than the light in your dash.
You do have an 02 sensor on each of the headers right? I'm not quite sure how the 98's work.2000 White Firebird <br />K&N Filter, Aluminum Driveshaft<br /><br />95 White Firebird - Laid to Rest<br />K&N FIPK, Flowmaster Exhaust, Jet Chip
Originally posted by blackfbird98 View Postok so my question about o2 emulators is if you get one will it work to fool the sensor that is BEFORE the catalytic converter?2000 White Firebird <br />K&N Filter, Aluminum Driveshaft<br /><br />95 White Firebird - Laid to Rest<br />K&N FIPK, Flowmaster Exhaust, Jet Chip
No no no. There are two o2 sensors that affect A/F ratio. one on each header/manifold. Those determine A/F ratio. There is a pre cat and a post cat o2 sensors. Those take further readings but don't affect anything regarding how the engine runs. Taking off the pre cat sensor won't affect anything, but i'm not sure if a sim would work in it's place. Either way you shouldn't need it because it's precat anyway... where are you planning on cutting your exhaust?
Originally posted by TheGr8Schlotzky View PostNo no no. There are two o2 sensors that affect A/F ratio. one on each header/manifold. Those determine A/F ratio. There is a pre cat and a post cat o2 sensors. Those take further readings but don't affect anything regarding how the engine runs. Taking off the pre cat sensor won't affect anything, but i'm not sure if a sim would work in it's place. Either way you shouldn't need it because it's precat anyway... where are you planning on cutting your exhaust?sigpic
Originally posted by kristen View Post2 o2 sensors all together. 1 on the drivers side header and 1 after the cat
Both left and right headers/ exhaust manifolds have an O2 sensor, then a post CAT O2.
For 97- there is an additional O2 sensor in the pipe just in front of the CAT.sigpic
Originally posted by bigbrian442 View PostThis is on 97 and older 3.8's. 98+ did away with the single O2 in front of the CAT.
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...3 weeks ago
