no o2 sensor - FirebirdV6.com/CamaroV6.com Message Board
no o2 sensor
  • no o2 sensor
    would it matter if i drove the car without the post cat o2 sensor plugged in?
    long story short, putting in a new exhaust. cut my exhaust off right before the cat and the exhaust needs to be cut different then i did and im sick of cutting and dont have the time to finish it today. so tomorrow i was just gunna drive it to an exhaust shop to have it all welded. but i have no cat and behind. other than the crazy loudness and the smell of carbon monoxide, will it matter?
    btw, i had to back the car out of the garage like this and it sounds amazing. i wish i could leave it like that.
    so, anyone?
    Re: no o2 sensor
    I believe unplugging the post cat O2 sensor will throw a code....if it hasn't already.
    If it will affect emmisions, I'm not sure.
    There are O2 sensor simulators, to not set off a code.
      Re: no o2 sensor
      its going to throw a code, and depending on where you live it is illegal, you will fail emissions and can get fined heavily if caught without a cat
        Re: no o2 sensor
        yeah ive already got the code and just driving a couple miles so im not too concerned with that. just making sure it didnt screw anything else up.
          Re: no o2 sensor
          no, your car won't self-destruct if you don't have a post-cat o2
            Re: no o2 sensor
            well thats a load off my mind
              Re: no o2 sensor
              actually it dose mess your car up because it runs Leaner i think which Makes you car run diffrent well it dosnt ruin it it just changes it which can lead to other problems if you dont fix it right
                Re: no o2 sensor
                yea, but in the context that the OP is questioning, which is
                ...his car isn't going to blow itself apart or keel over and die
                  Re: no o2 sensor
                  Since when did the post cat O2 sensor effect a/f?
                  TEAM C6V6
                    Re: no o2 sensor
                    It doesn't. Running without a post cat o2 sensor will not affect your car in any way, shape, or form, other than the SES light.
                    1996 Chevrolet Camaro
                    1995 Buick Park Avenue Ultra
                    --Appearance Moderator--
                      Re: no o2 sensor
                      Exactly.
                      TEAM C6V6
                        Re: no o2 sensor
                        now i cant decide if i wanna risk driving it and have to try and avoid police in my small town or if i should get it towed which should be free because its close by.
                          Re: no o2 sensor
                          If you're just driving to the exhaust shop, tell the police that and they will more than likely leave you be if you do happen to get pulled over. Just don't hotrod around with the exhaust off, take it easy.
                            Re: no o2 sensor
                            how many hours do you think an exhaust shop would charge just to weld up an exhaust? i cant imagine it being much more than 1 hour. what do you think?
                              Re: no o2 sensor
                              Shop charged me $100 labor to install my exhaust with few of their adapters, and the bending and welding of the muffler back with their pipe, as well as welding on my tips.
                              If you have all the parts, it should be less than that. Give them a call though they can normally get you a good estimate.
