Where to buy aftermarket intakes for the 3.4? - FirebirdV6.com/CamaroV6.com Message Board
  • Where to buy aftermarket intakes for the 3.4?
    Are you guys using ebay or buying K&N FIPK's? I am wondering what intakes you guys are buying. I am looking for one that will eliminate the use of the factory 90 degree tube off of the TB. I need one that will start out with a 90 degree coupling off of the TB. Do you guys have any suggestions. Since I am new to the 3.4 I only know to check ebay and summitracing. Thanks for any help.
    Re: Where to buy aftermarket intakes for the 3.4?
    you could always make your own!
      I threw one together with a K&N cone and tubes from Autozone, then I routed them inside the driver's fender through the gap that the original filter left. One of the bigger driveability differences I noticed. Total cost, perhaps $75, including the price of the K&N.
        is your piping stainless tubing? What did you do about hooking up the IAT sensor and the breather hose to the intake?
          I like the ones from ChromeIntakes on ebay.
            like this one? http://cgi.ebay.com/ebaymotors/93-94...ayphotohosting
            that is still using the stock tube off of the TB. That is one of the problems I am running into, it seems like most of them use that tube and that tube comes out too far for my use, I am hoping to find something that 90's straight off of the TB. I only see one on ebay that does not use the stock tube off of the TB and that one uses a sraight pipe before it bends so that is taking away clearance as well.
              No, more like this one
                That one does look better. Do you have a picture of this one installed or know where I can find one? More like a top side view so I can see the clearance.
                  I am sure someone on this forum has this intake.
