So after using this forum to pick out my Whisper Lid / SLP CAI and 2.5" Magnaflow Cat-back setup, I'm working my way from the ends to the middle.
After searching through the forums I've come to the conclusion that the Magnaflow / Carsound #94009 is recommended as the cat of choice as it is the same length as our stock cat? Would having a 3" ID in / out catalytic converter hurt me as the rest of my tubing is 2.5"? I understand that my exhaust is as good as the smallest part, but would going bigger cause any problems?
I've read that people said going with the 3" cat is easier because the stock Y-pipe collector and the Pacesetter Y-pipe collector is 3" and it is easier to reduce after the cat than before. Others have said that having 3" going into the 2.5" is one less part they have to replace in case a full 3" conversion happens down the line. I understand 3" is required for FI but I don't exactly plan on going that far into modding this daily driver.
So, in TLDR format, with a 2.5" cat-back, would having a 3" in / out cat and S-Pipe hurt me at all (flow or sound) or would it be the same as having a 2.5", maybe even better?
