Solution for Pacesetter header gaskets yet?? - FirebirdV6.com/CamaroV6.com Message Board
  • Solution for Pacesetter header gaskets yet??
    Has there been a solution for header gaskets for the Pacesetters yet?
    I first had Fel-pro, and those leaked baddd. Then I switched to the paper ones that came with the Pacesetter headers and it was fine.
    Now last year, I had my engine and trans replaced and my mechanic used some stock gaskets or something and they leak again like the fel-pro. So wondering if anyone has found anything that seals up better than the Pacesetter gaskets. IE: Clear image gaskets, Abbott racing gaskets, etc.
    99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
    Re: Solution for Pacesetter header gaskets yet??
    A lot of people use Abbott racing Gaskets.
    I would suppose they are pretty good.
      where would i order those, I was on their website, but didnt see anything bout the header gaskets
        email/PM Wicked98Six
          Fel pros and copper spray works great.
            abbott ftw!
            Y87 Package
            MOGOB APPROVED!
            BONE APPROVED!
            VANBIBBER APPROVED!
            KRISTEN APPROVED!
            Vice Prez.
            Team Black...TEAM EMO
            Come on kids! Get a Calendar!
              I just ordered a pair of abbott gaskets, ive only heard positive things about them soo..
              abbott ftw x2
                I'm also a supporter of abbott gaskets.
                TEAM C6V6
                  Yea that's what I heard too, but its been a while since I remembered which ones I was gonna buy haha, but so I'm guessing the abbott ones are shaped exactly like the pacesetters are more circular then oval like the stock manifolds and gaskets?
                  Also what material are the abbott gaskets made out of?
                    no, they are oval. from lance:
                    "Abbott Racing Heads has your fix. Made for the 3800 series II, these gaskets are made from 1000* exhaust gasket material that will not burn out like conventional paper gaskets. They are patterned after our ported heads but will also fit stock heads. These will work on any car as long as it's a 3.8L."
                      With the abbotts you have to do some trimming so the flow and line up perfect.
                      Checkout the sticky "considerations when installing new exhaust"
                        I've had great luck with the Fel Pros they are oval like the exhaust ports. I just sprayed them down with copper spray gasket sealant, let them sit for about an hour then install. They have 2 open slots so you can put 2 bolts back in a little bit, then you slide the gasket in. Then just put in the other bolts, I started with the 2 ends just to make sure it was lined up correctly, then just torque them in order. I retightened after running it a couple of good heat cycles then retightened them again. Then just check them when doing maintance items like oil changes, plugs , wires etc.
                          +1 for Abbott gaskets.
                          1997 Camaro RS A4
                          2006 Chevy Colorado
                          2003 Kawasaki Ninja ZX6-R
                            No question on the Abbott gaskets. They are around $35, too. Not a bad investment. Get the stage 8 locking header bolts and you shouldn't have a problem with leaks. Just follow the directions on the Pacesetter headers for installation.
                            2000 Camaro V6<br />I\'ve done nothing to my car worth note. :)
                              Those are worthless and huge waste of money. I had those and they didnt even lock correctly :rolleyes:
                              I got some regular run-of-the-mill bolts from O'Reilly's for about $10 (I cant remember the exact size) and they havent come loose yet.
                              1997 Camaro RS A4
                              2006 Chevy Colorado
