Good morning. My 96 3.8 camaro has oil in the radiator. One person tells me it's the intake gasket that is leaking into the water, and to change the gaskets. Another one tells me that oil can't get into the cooling system that way?. That it has to be something else. Any help before I get into it would be great. Thank, Pat.
Intake gasket
Re: Intake gasket
Nuh uh... Intake gaskets failing won't get you oil in your coolant.. Oil in your coolant means you've damaged your block. It's not a very common problem to encounter.. The time I cracked a block I was told to look for oil in the coolant as a sign to tell if the block was cracked.. You're most likely going to have to get the block and the heads magnafluxed to see if they're cracked.. Sorry dude.. That sucks..Last edited by Timwiltshire; 07-19-2008, 12:39 AM.
Re: Intake gasket
Make sure it's oil and not Trans Fluid if you have an A4.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Re: Intake gasket
Originally posted by Timwiltshire View PostNuh uh... Intake gaskets failing won't get you oil in your coolant.. Oil in your coolant means you've damaged your block. It's not a very common problem to encounter.. The time I cracked a block I was told to look for oil in the coolant as a sign to tell if the block was cracked.. You're most likely going to have to get the block and the heads magnafluxed to see if they're cracked.. Sorry dude.. That sucks..
A leaking upper intake gasket, lower intake gasket or a throttle body gasket can mix oil and coolant. The throttle body gasket leak is a common way for this to happen.
I HIGHLY doubt the block is cracked.Last edited by Shodown; 07-19-2008, 09:53 AM.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Re: Intake gasket
Originally posted by Pop's 96 View PostTranny fluid? Could my tranny cooler be leaking mayby in the radiator?Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
