okay so i have a 94 camaro 3.4 the intake pipe kept coming off the the airbox... so i went too pep boys and bought some flex house to make my own cai... so i kept the stock 90 degree elbow that the iac plugs into and the vaccum line plugs into... i used the flex hose to go into the wheel well where like a k and n fipk goes... used a cone filter also.. now i am getting a check engine light that i didnt have.. i had the normal egr b.s. one... any ideas on why cause i figure its the same as the k&n one.. also i disconnected the battery to reset the comp to see if that would help and it didnt
homemade cai gone wrong
Re: homemade cai gone wrong
Might just be the IAT sensor since you unpluged it or a wire is loose. I would double check the connections if the light is coming back on.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
What is the code it is throwing?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
okay guys scanned the car on my way to work... it is saying MAT is too low???.. what does that mean???... wierd thing is that when the check engine light comes on and i scan it that dosent come up only my egr code comes up... that MAT thing is in the history codes
Your flex hose sucks. Get rid of that crap. It could be impeding or redirecting the air somehow in a way to effect the MAF sensor. Or are there MAF screens on those cars? If removed reinstall asap. I dunno, it could be a number of things. But obviously it's probably your home grown kit since the problem arose when you installed it.. right?
TEAM C6V6
mat
manifold air temperature
iat
intake air temperature
two names for the same sensor, just depends where its placed.
also no maf on the 3.4.<a href=\"http://www.cardomain.com/ride/2265676\" target=\"_blank\">95 bright red camaro 3.4l</a>
if you dont want the stock intake elbow, check out the ebay intakes.
ive had one for a while now and as far as i can tell with the butt dyno, it was an improvement.
something like this:
http://cgi.ebay.com/ebaymotors/93-95...mZ120291339877
i paid a lot lot less for mine though.<a href=\"http://www.cardomain.com/ride/2265676\" target=\"_blank\">95 bright red camaro 3.4l</a>
