HI Flow Cat - FirebirdV6.com/CamaroV6.com Message Board
HI Flow Cat
  • HI Flow Cat
    I Have A 2002 V6 Camaro and I have a Magnaflow CATBACK and I'm getting Pace headers installed in a few weeks. Would I notice a difference if I also installed a HiFlow catalytic converter or is just a waste. Thanks- :banana:
    Re: HI Flow Cat
    yes, you'll notice a difference. No, it is not a waste
      Re: HI Flow Cat
      x2 you might as well make a new s-pipe also.
      -Y87
      Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
        Re: HI Flow Cat
        If you keep your stock cat and s-pipe then you've created a bottleneck in your exhaust.
          Re: HI Flow Cat
          Yup your compression from the exhaust will not flow correctly if you still have the stock cat. I've heard either Catco or Magnaflow cats are good. I suggest getting one, it has helped opened my exhaust pretty well.
            Re: HI Flow Cat
            i have a pacesetter high flow cat. works well. better than no cat or a gutted cat
            WAWA-A-HOLIC
              Re: HI Flow Cat
              Like people have said, you'd need to upgrade the diameters of your stock cat and s-pipe or the catback would really be a waste.
