!egr - FirebirdV6.com/CamaroV6.com Message Board
!egr
  • !egr
    so my headers are on order and i was thinking about !EGR.
    Because from what ive read is people have problems with the EGR leaking.
    So should i order block off plates or just try to seal it up?
    -Y87
    Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
    Re: !egr
    Block off plates. It'd be better to lose the weight and it's always nice having more space in the engine bay. You can cut and weld the headers EGR extension off and even make your own block off plate for the manifold. It's what I did and it's worked great so far. Just make sure to use some gasket maker for the manifold plate.
    TEAM C6V6
      Re: !egr
      who sells blockoff plates?
      -Y87
        Re: !egr
        I think ZZP? That sounds right but I'm not positive.
        TEAM C6V6
          Re: !egr
          I can make you some if you want them.
          $5 shipped for both, not each.
          Y87 Package
          MOGOB APPROVED!
          BONE APPROVED!
          VANBIBBER APPROVED!
          KRISTEN APPROVED!
          Vice Prez.
          Team Black...TEAM EMO
          Come on kids! Get a Calendar!
            Re: !egr
            I will probably end up making my own but ill let you know if i need them.
            -Y87
              Re: !egr
              Alrighty then bro!
              Y87 Package
              MOGOB APPROVED!
              BONE APPROVED!
              VANBIBBER APPROVED!
              KRISTEN APPROVED!
              Vice Prez.
                Re: !egr
                Just use your existing covers and weld a nickel in where the hole is. Then use some copper RTV to seal them up. I did mine, the one on the upper manifold came out perfect, no leaks and didn't have to use any RTV. The one on the headers was leaking bad, weld job sucked, had it set too high and melted most of the metal. So I used another piece of metal with copper RTV and it sealed it up. Copper RTV is your friend. LOL
                  Re: !egr
                  just delete it. but keep for when you have to go in for inspection
                  WAWA-A-HOLIC
                    Re: !egr
                    i dont have to worry about it i live in MI:banana:
                    -Y87
                      Re: !egr
                      I wouldnt go welding anything to your motor if I were you...
                      Y87 Package
                      MOGOB APPROVED!
                      BONE APPROVED!
                      VANBIBBER APPROVED!
                      KRISTEN APPROVED!
                      Vice Prez.
                        Re: !egr
                        i wouldnt either. im just going to use blockoff plates.
                        -Y87
                          Re: !egr
                          :tup:
                          Y87 Package
                          MOGOB APPROVED!
                          BONE APPROVED!
                          VANBIBBER APPROVED!
                          KRISTEN APPROVED!
                          Vice Prez.
                            Re: !egr
                            I may block mine off too. It isnt leaking, but I did turn it off in the tune, so its just a pretty part under the hood that does nothing.. Kinda like a blow off valve speaker in Hondas. lol
