on their block off plates.. is there something on the plate that fits inside the stock exhaust manifold? i had some made but they are smooth top and bottom side and i fired up the car... tick tick tick... exhaust leak so i torqued it down more and of course when you tighten it up it wants to rotate with the bolt but i got it to stay in place with some vise grips.. but i am still leains out some air there i do have a metal exhast gasket between the manifold and the plate.. i just need to know if theres actually seals it off or is it smooth on both sides too?
zzp egr block off question..
Re: zzp egr block off question..
Originally posted by Meatyshells View Postjust use some cooper rtv or something to seal it08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
The one on the upper manifold should seal without using any RTV.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
there's is just a flat piece of metal, nothing that goes into the manifold. Yes it will want to rotate. I run the plate on my headers right now
Originally posted by vr4gasm View Postintake sealed fine i used some copper rtv spray i will get a tube of the thicker stuff and see how it goes..
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...2 hours ago
