How exactly would one go about gutting a cat? also does anybody know if the stock cat on a 2001 is welded on or a bolt on?
Gutting a Catalytic Converter
Re: Gutting a Catalytic Converter
you tie it up, stretching the front & rear legs apart. take a knife & slit it........ oh, the other cat... get a pipe & bang the shiz outta it like it a $5k whore, let the crusty stuff shake out like a 5cent whore, then repeat until there's nothing left to bang, like a 97yr old whore.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
You will probably be able to unbolt the engine side of it, and have to cut the rear pipe. Make sure you cut in a place that is easier to get to with a welder. Once you get it off take a piece of pipe or bar and hammer it through cat to break up the inside. You should be able to see inside of it to make sure you get it all.
Originally posted by 3.4 slow to go View Postyou tie it up, stretching the front & rear legs apart. take a knife & slit it........ oh, the other cat... get a pipe & bang the shiz outta it like it a $5k whore, let the crusty stuff shake out like a 5cent whore, then repeat until there's nothing left to bang, like a 97yr old whore.
