Well I'm gonna tear into it and change my upper and lower intake gaskets. Hopefully, that will fix my coolant problem. I was wondering if the felpro gasket set you get at autozone will be good or do I need to order them from gmpartsdirect? Also what other parts will I need to replace while im in there? It's a 2000 camaro 3.8 m5
1. air plenum gasket set
2. lower intake gasket set
3. injector o rings
4. valve cover gaskets
does that sound right? do i need to replace any bolts on lower intake? any tips or advice would be appreciated. I will take a lot of pics while i do this. Maybe I can do a good write up after I get it done.
3. injector o rings
