gonna replace my intake manifold gaskets - FirebirdV6.com/CamaroV6.com Message Board
  • gonna replace my intake manifold gaskets
    Well I'm gonna tear into it and change my upper and lower intake gaskets. Hopefully, that will fix my coolant problem. I was wondering if the felpro gasket set you get at autozone will be good or do I need to order them from gmpartsdirect? Also what other parts will I need to replace while im in there? It's a 2000 camaro 3.8 m5
    1. air plenum gasket set
    2. lower intake gasket set
    3. injector o rings
    4. valve cover gaskets
    does that sound right? do i need to replace any bolts on lower intake? any tips or advice would be appreciated. I will take a lot of pics while i do this. Maybe I can do a good write up after I get it done.
    2000 Camaro 3.8 v6 M5
    Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
    Re: gonna replace my intake manifold gaskets
    nows the time to change your lifters if they are no good....
      Well I haven't had any problems with my lifters they are quiet. I got 100k on the motor. Should I change them anyway?
        if your not having a problem than i wouldn't
        thats a good kit. i used it after my nitrous backfire
        WAWA-A-HOLIC
          Since you'll be that far in, how about taking off the heads and getting them P&P'd?
            felpro makes good gaskets, they will be fine.
            i would also suggest to replace the lifters, especially if you plan on keeping the car for a lot longer
              ok thanks for the replies! I'll use the felpro gaskets. Do I need to get those coolant elbows? I looked in the help section at autozone they didn't have anything like that. So can I reuse all bolts that i take out? I just want to make sure I have everything I need so this goes as smoothly as possible. This is gonna be a good learning experience for me! I need to get a good torque wrench. Any other specialty tools I need? What about locktite and rtv? Thanks!
                Autozone can order the elbows. If you wait til tomorrow, I'll grab the part numbers while i'm there. You should be able to reuse them with no problems though. I would reccomend changing out the lifters. They are fairly easy and will save you from having to do them in the future
                Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
                  ok, i'm not in any hurry. I still have another week and a half before i'm off work. Once I have the lower intake off, what do I do to replace the lifters? I don't want to pull the heads. Thanks!
                    to replace the lifters you will have to remove the rockers, pull the pushrods out, remove the lifter retainers, then pull the lifters out.
                      Personally I wouldnt mess with the lifters at this time because I would have a cam swap planned for the future. Once you pull the lower intake bolts you can then determine if any need replacing. If you have access to a sand or bead blaster you can get all of the carbon build up out of the upper plenum. This would be a good time to port the UIM & LIM to match the gaskets. Put blue loctite on the LIM bolts, and follow the tightening sequence and torque specs.
                      Are you going to paint anything?
                        No I wasn't going to paint anything, just try to clean everything up as best as I can. I thought about using the seafoam in a spray can to clean upper plenum. I don't have access to a sand blaster. Thanks!
                          seafoam works very well
                            if you have an o'reillys close, i would go there and see if they have some of those elbows, cause your gonna break em.
                            if you do lifters (why would you, if it aint broke, dont fix it) you would need new rocker bolts.
                            dont pull the heads, pita. you will then have to buy $120 worth of head gaskets, new head bolts, and rocker bolts. you have to make sure that the heads are gasket free and the block is clean, and chase the bolt holes. and as you state the intake will be a learning experience so i would hold off on doing the heads. again, if it aint broke dont fix it.
                            Team NoVa
                              with his mileage, it would be good to go ahead and take care of inspecting everythign else while he has it apart. That's just the way I always thought of things. better to be safe than sorry
                              • Manimal
                                Coil springs
                                by Manimal
                                6 days ago
                              • Manimal
                                Newby here
                                by Manimal
