sensor problems - FirebirdV6.com/CamaroV6.com Message Board
sensor problems
  • sensor problems
    i have a problem with my car right now, i think it might be the throttle body but im not sure. It has problems stayin running when i first crank it like if you give it gas it will sputter a lil bit, and some times it throws the reduced engine power light and sounds like its got a t rex cam in it or something but wont go no where. My cruise control also doesn't work right now. I took off the throttle body about 2 weeks ago and completely cleaned it out and cleaned the maf with maf cleaner. cleaned the screen and everything but it still does it so im baffled. I know its throwin a code for the maf but i have no idea where to get a new throttle body, any answers?
    99' firebird 3.8
    pacesetter headers, single chamber flow, no cat, spec flywheel, spec 2+ clutch, 02 ss rear end.
    Re: sensor problems
    If it's throwing a code for the maf you can replace just the maf sensor IN the throttle body no need to replace the whole throttle body.
    It also sounds to me from the brief description that you may have a misfire or multiple misfires above and beyond the maf issue.
    What all codes is the computer tripping?
      Re: sensor problems
      well its tripping the knock sensor but it was unplugged from when i put in my clutch i forgot to hook it back up, the egr and the rear o2 sensor. Its not a misfire cause once it warms up i usually dont have any problems with it but every once in a while. Once it warms up it runs fine and smooth. What do you think is up with the cruise though? and it cant find idle if your cruisin down the road at about 10mph or more, it will go up to 1100 or so and fall to 600.
      99' firebird 3.8
        1 day ago
