My Exhaust / Intake set up... - FirebirdV6.com/CamaroV6.com Message Board
  • My Exhaust / Intake set up...
    Alright... Well, this is my first post here, and I figured I should make it a decent one!
    This is my new exhaust/intake set up, that I did myself...
    Before the pictures, I'm going to explain a bit on what I did -
    Rather than get all new pipe (cost and time prohibitive) I decided to reuse the stock pipe with my new muffler (Dynomax Superturbo). In doing this, I learned quite a bit about exhaust, and the issues that are inherently involved.
    My main problem in reusing the old pipe was that the ID/OD were 2.5" while the pipe was 2.25" I solved this problem by getting 3 pipe reducers. When I went to attach the pipe reducers to the muffler, I found that they had identical ID. So, I went and got 3x2.5" pipe sections to connect the reducers to the mufflers.
    Next, I found out that the reducer/new pipe sections made the tips about half a foot too far apart to fit properly in my body kit (W68). So, I had to cut a few inches off of each pipe. However, I accidentally cut too much off of the drivers side pipe, and now the pipe shot out at 45*... So, I went and got a 45* bent 2.5" pipe to replace in between the muffler and the reducer. This solved the problem, and everything eventually lined up perfectly!
    I then hoisted everything up under the car, and tightened down the last few bolts and clamps, only to find out that the muffler wanted to sit to the drivers side about an inch too far. A little wire and some careful coercion, and I managed to get everything to sit together nicely.
    I'm not completely satisfied yet, as I've been told twice that it sounds "ricer" at higher rpms (I'm assuming they're just hearing the rasp) so I plan on replacing the cat with a glasspack. Also, the muffler sounds vastly different at WOT on the road vs. 5k rpms at a stop.
    Now for the fun part! Pictures!
    Drivers Side Out -
    Passenger Side In/Out -
    New Muffler, Whole thing -
    Now, for the second part of this post!
    I've also done the air box lid mod, and the air resonator delete...
    These are pretty well known, so I won't go into too much detail, other than the part I used for the gap from the air resonator. I was looking around for a steel pipe for a while, or aluminum, or even PVC, and couldn't find anything I wanted to use. Finally, I was bumming around in menards looking for a suitable part, and found a 3"x3" PVC pipe coupler. I bought it on the spot for $4 and some change, and went home to start my mod. Here's the final result!
    Air Resonator Delete -
    Most people don't realize anything is out of the ordinary unless I tell them about it... So I think I did a pretty good job!
    Re: My Exhaust / Intake set up...
    Now for Part Two! Couldn't post more than 4 images, so I had to break this up a bit...
    Airbox Lid Mod -
    Then, just to wrap this post up, here's a couple pics of my car -
    And finally, my engine bay (in it's nasty, dirty, unkept state) -
    Alright, well, that's all I've got for now... So.. Let me know what you think of my set up, and any comments/tips are greatly appreciated!
      Pretty Car, but the muffler with stock piping really isn't going to provide any real gains...the true gains come from the piping going from 2.25 to 2.5 or 3 makes a world of difference flowwise...
      Y87 Package
      MOGOB APPROVED!
      BONE APPROVED!
      VANBIBBER APPROVED!
      KRISTEN APPROVED!
      Vice Prez.
      Team Black...TEAM EMO
      Come on kids! Get a Calendar!
        how did you do the airbox mod, did those fins just snap off or what
          Needle nose pliers makes it pretty easy.
          '99 Camaro
          '04 Saab 9-3 Aero
          '90 Audi Coupe Quattro
            so i just snap them off and use some sandpaper to make everything nice?
              superturbo muffler sounding like rice......thats the first Ive heard. More then likely the 2.25" piping. Anyways car looks good.
                That is the word on the street, I thought about doing that but I just said eff it and got the whisper lid
                  for my lid i accully used a grinder carefully then torched the lid to make it baby bottom smooth worked well felt slight gain (not much)
                    btw car looks nice but find someone with a welder and rid ur self of the clamps
                      i have a k and n fipk to stock manifolds and 3" pipe back to my super turbo no rasp at all no rice here must be your crappy pipe..
                      2001 Camaro 3.8 A4
                      1991 3000GT VR4
                      2001 Mitsubishi Eclipse GS
                        xxxx2
                          You've got a great start though, improvising and doing things yourself is always a big :tup: in my book. Keep goin, free up that flow all the way up to the heads and you'll be set as far as exhaust piping is concerned.
                          TEAM C6V6
                            oh yah i forgot i have a carsound high flow cat too
                            2001 Camaro 3.8 A4
                            1991 3000GT VR4
                              removing the air resonator didn't flip any codes?
