I am getting that code. Does anyone know what I could replace to fix that? I'd read it could be the purge valve or the carbon canister itself, but nothing solid I've been able to find?
Engine Code 1441 "Purge During Non Purge Conditions"
Re: Engine Code 1441 "Purge During Non Purge Conditions"
Originally posted by DerekGlidewell View PostI am getting that code. Does anyone know what I could replace to fix that? I'd read it could be the purge valve or the carbon canister itself, but nothing solid I've been able to find?
I replaced a few different things, then I finally saw the problem...
My old thread, post #4.
I'll try to find a picture of what I did to solve the problem. It was an easy fix. At least, it was easy in my case.Last edited by hockeyman; 05-11-2009, 12:37 PM.sigpic
I replaced the plastic line with a 3/8" fuel hose. I circled the replacement line in the attached picture.
If that's not the problem, post it here. Before I found that broken line, I put in a new canister, fuel tank pressure valve, one (1) O2 sensor and purge valve.sigpic
Originally posted by DerekGlidewell View PostMine is 1996, so I'm not sure if that's why, but I don't have one of those hoses connected to my throttle body.
That hose goes from the side of the throttle body to the purge valve -behind the alternator. If yours isnt there, connect them with a new hose, drive the car for a bit and see if the ses light goes out.sigpic
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...4 days ago
