Tryna to shave off a little more weight... I got an aftermarket exhaust system, but it is aluminum piping, not stainless steel...Is it still safe for me to remove the heat shields that follow the I-pipe all the way to the back?
exhaust shielding
exhaust shielding
Project Cars | How To Guides | Scratch Repair | Synthetic OilTags: None
Re: exhaust shielding
no one?
ya aluminized steel...a few pounds...but with weight savings its a few lbs here and a few lbs there...will all start to add up... I was thinking of leaving the gas tank heat shield...but I want to take off the shielding all under the passenger side of the car following the I-pipe back...I've heard its ok to do so with an aftermarket system...but I know most systems are stainless steel, and not aluminized steel...so I'm not sure how much my pipes actually hold in the heat...
Originally posted by cam98aro View Postdo you live in an area where they do car inspections?
I'm not sure if they look for that...I'll have to find out...I know we do emissions, and some sort of a visual inspection...so ya I need to leave the cat on...but the shielding by the cat you are talking about is actually attached to the cat right? I'm referring more to the shielding attached to the underbody of the car...
Originally posted by LETZRIDE View PostI'm not sure if they look for that...I'll have to find out...I know we do emissions, and some sort of a visual inspection...so ya I need to leave the cat on...but the shielding by the cat you are talking about is actually attached to the cat right? I'm referring more to the shielding attached to the underbody of the car...
fail emissions or fail safety?
im not worried about safety...that only gets done when you sell the car right?
