Obx headers leaking. - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Obx headers leaking.
    Problem with both those solution is the way the joint is designed. The "Ball joint" design they used needs to be held together tight but allowed to move as the engine moves with torque. Thats why they have springs. If you tighten the bolts too tight when its cold the joint will not slip and the joint will get damaged. You can put it at the right torgue when its cold but once the bolts get hot the joint will get too loose and leak. The spings allow the bolts to grow and shrink but still keep equal correct presssure on the joint at all times.
    If you install a sealer it may hold for a little while but since the joint is designed to move it will and when it does the sealer bond will be broken.
    I will need to get my car jacked up to take a picture. But the fix I came up with is easy and will allow the joint to work as its designed. I think I spent $10 at the local hardware store.
    • #17
      Pacesetters are built the same way and don't use the springs. I have had zero problems with them in over 3 years. You do have to be careful about not over tightening them.
      • #18
        Thats cool, Saves me from jacking up my car.
        • #19
          ok your supposed to put the springs through the bolt between the header and the flange right? i did that but the springs are too short so when i tighten it the springs hold not tention and just rattle.
          • #20
            UM........NO!
            Between the nut and the flange on the Y pipe.
            • #21
              Originally posted by bigbrian442 View Post
              UM........NO!
              haha thats what i taught when i was installing it but there is no way that can be done the bolt is no where long enough but if it wount do damage with out it ill leave it as it is
              • #22
                I would just take the springs out and replace the nuts with an all metal lock nut.
                • #23
                  ok i did the rtv copper and it stopped the flange leak as far as i could tell and the egr but it sounds like something is still leaking,sounds like a slight misfire at idle which is reading lean,i let it warm up and the idle was weird and sounded exactly like i have a cam in it thats when the AFR would read 18.0 but after a bit you see it starting to go towards the rich mark and it idles pretty good but stays at mid 15's to high 15's and at crusing it will be between 14.8 to 15.3 i think this is normal right?
                  • #24
                    quick question,what is the purpose of a breather on the valve cover,by doing this does it get rid of the vacume lines like the pcv valve etc? because i want to get rid of those things is there a way to do this?
                    • Manimal
                      Coil springs
                      by Manimal
                      5 days ago
                    • Manimal
                      Newby here
                      by Manimal
