where did everybody else using a wet kit put the micro switch at or how did you mount it pics would help, thanks.
Micro switch placement (Wet Kit)?
Re: Micro switch placement (Wet Kit)?
mount it on the tb then so that when the tb cable is at wot it clicks it.
doubt it, I removed mine a couple years ago when I switch setups. There is a metal square rod on the side of the tb by the spring. I threaded it into that hole there and bent the switch bracket around into position
I mounted mine underneath the gas pedal. This way I could go to WOT without hitting the switch, but if I pushed on the pedal a bit harder, it clicked. I doubt I'll find any pics though, sold that car nearly 7 years ago.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
