Nitrous - FirebirdV6.com/CamaroV6.com Message Board
Nitrous
  • Nitrous
    Do you have to run a nitrous filter, blow down tube and purge kit to run nitrous or can you get by with none of this?
    Re: Nitrous
    They are accessories and are not crucial to the operation of the system, but they are good to have.
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
      Re: Nitrous
      ok harris speed works has a sale for $280 for their wet kit. I will have a window switch and bottle warmer. Are the things I mentioned that I won't have easy to add later on down the road?
        Re: Nitrous
        Yes, they are very easy to add.
        1997 Camaro RS A4
        2006 Chevy Colorado
          Re: Nitrous
          if you are running it at the track you need a blowdown tube to vent it out of the car. Purge kit and nitrous filter are add ons that help the kit perform to its max. A purge helps make sure you are getting the full shot of nitrous as soon as you hit the button and then drain the pressure when done running
          http://www.bowtiev6.com/
            Re: Nitrous
            What drains the pressure?
              Re: Nitrous
              the purge, when you are done you close the bottle then purge. This releases the pressure and nitrous in the line. Without it your have that pressure and nitrous sitting in the line the whole time
                Re: Nitrous
                is that bad to have?
                  Re: Nitrous
                  It puts constant pressure and strain on the solenoids and can wear them out prematurely. If you dont have a purge you can just loosen the bottle nut (or the fitting on the bottle nut, whichever) and slowly bleed out the pressure when you're not using the system. Be careful though, do it very slowly so you dont freeze your hand.
                  1997 Camaro RS A4
                  2006 Chevy Colorado
                    Re: Nitrous
                    haha ok i can use gloves then. Looks like I will be getting the kit then. I already bought the MSD window switch from radracer and trying to find a bottle heater new but someone bought it and didn't use it(having hard luck).
                      Re: Nitrous
                      Which plug should I switch to? I have Beene reading on various websites the tr6 and I think the br7e. Which do you guys use. I don't know of o will spary a 75 or 100 shot yet.
                        Re: Nitrous
                        TR6s are what you will want
                          Re: Nitrous
                          I should gap them a .35 right?
                            Re: Nitrous
                            read the stickies here in the nitrous section, everything is in those that you need to know ;) http://forum.camarov6.com/showthread.php?t=77576 is a good one to start with.
                              Re: Nitrous
                              yea i have read them. Just wanting to clarify. Stuff does change over the years.
