Is lower compression for nitrous a good idea I have a thread in advance eng. So i will sum it up I spun a rod bearing in my motor gettin a used GTP for really cheap compleat engine and want to use the block instead of rebuilding my motor. what do you guys think?
lower compression for nitrous?
Re: lower compression for nitrous?
nitrous likes more compression. So go with a higher compression setup.
X2 , if you can get it to close to 10:1 it would like it alot, but if you use MLS gaskets stick with a 4 layer for extra protection.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
