I think I have a bit of a leak.
Ya'll ain't gonna believe this ****.
Re: Ya'll ain't gonna believe this ****.
I assure you, it's connected, and the fittings are tightened down well. I belive it was mis-machined at the factory. No matter what I do, it has two pinhole leaks on the inlet and purge port.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Originally posted by Bird_Of_Prey View PostI assure you, it's connected, and the fittings are tightened down well. I belive it was mis-machined at the factory. No matter what I do, it has two pinhole leaks on the inlet and purge port.
That doesn't look too good , I would guess he used paste on the fittings since hes been running nitrous for awhile, I had a leak on my main 16ft. line it got pitched or something and leaked like crazy.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by transamtom1 View PostWhat type of sealer did you use on the threads?<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
You should be good with paste, I have used tape and thread sealer on some parts and never had problems aslong as you put it up high on the threads and it doesn't get sucked in and clog a jet or filter. I agree def. let it sit over night, I do on most of the sealants and agsket makers I use , esp. for the oil pan and intake mani's. Use blue loctite med. not the red if you going to use loctite.Last edited by ssms5411; 06-14-2010, 02:41 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
instead of tape try liquid thread lock. You can get it from any home improvement place. It works into the treads better than tape. It's a lot better I think. I used that stuff for my bathroom remodel and I was sold on it. I was also told by a guy I used to work with that tape is the worst thing you can use. He was a pipe fitter for 25 years...
Originally posted by 1320smokeshow View Postyou shouldn't need to run teflon paste and its strongly discouraged by all nitrous kit manufacturer's. pipe thread should be self sealing and so should AN fittings. i think you need parts replaced.www.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by 02silverbird View Postinstead of tape try liquid thread lock. You can get it from any home improvement place. It works into the treads better than tape. It's a lot better I think. I used that stuff for my bathroom remodel and I was sold on it. I was also told by a guy I used to work with that tape is the worst thing you can use. He was a pipe fitter for 25 years...<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
yes use paste and not tape on pipe thread. AN fittings should not need anything.
Is it the crimp connection on the line itself leaking? Mine did the same on the bottle side! Ended up needing to have a new connector put on the one side!!Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
2002 WS6 T/A.. Bolt ins..448rwhp
2009 G8 GT.. Vararam intake, GXP axleback
1998 Corvette.. Vararam intake, Ti axleback
http://www.fquick.com/slow-v6
